In my hz holden the light stays on same as the boot light.Could it be a bad earth somewhere!
cheviot,
Feb 6, 7:35pm
Could be the headlight switch. Twist the light switch knob to see if it turn it off.
jono2912,
Feb 6, 7:36pm
In what circumstances does it stay on! Does it turn off at all!
jasongroves,
Feb 6, 7:43pm
Check the switches located in the door and boot sill area. One is probably sticking or otherwise faulty. Unless its staying on all the time (no matter what position switch is in)!
richms,
Feb 7, 4:14am
Could be a bad alarm install or removal as well.
In a friends hatch when they did the alarm install they connected the boot light and the car light together into the alarm.
typhoon666,
Feb 7, 4:22am
The door switches seem ok and it does not make any difference with the headlight switch they just stay on all the time.Its been sweet till the other night i noticed them on.
saxman99,
Feb 7, 8:11am
My car did this too.It was caused by a door switch wire which had broken away and was touching the body inside a cavity, thus earthing it and bringing the lights on.
jsbike,
Mar 20, 5:14pm
I 2nd that, that caused mine with the same prob. I wire that ran under the back seat to the boot switch was pinched under the seat and earthing out.
