Ford Futura .Red "fan" icon light on dashboard.. Can anyone help me with an electrical problem i have a ford futura 19
bubbagum,
Feb 2, 6:11pm
Can anyone help me with an electrical problem! I have a ford futura (1996 or 7)!.I have a red light showing on the dashboard it is a "fan" icon.Comes on and off while driving.Can anybody tell me what this light is for! would much appreciate your reply.
Thanks.
curlcrown,
Feb 2, 6:13pm
It is low coolant warning light. However it is very commen for them to malfunction and come on when the collant is not low. Check coolant level and if it is not low ignore it. The sencor is in the header tank.
fordcrzy,
Feb 2, 6:16pm
probably crap in the tank.
remove it and clean the tank out
nave12,
Feb 2, 6:24pm
That is what it will be,you can replace the sensor as the plastic float becomes brittle and cracks and fills with water so yours is probably on its way out or already gone.
jason18,
Feb 2, 6:34pm
Yeah mate had same prblem. Was a stuffed sensor but check coolant isnt low first
neo_psy,
Feb 2, 6:39pm
That seems a drastic fix.
extrayda,
Feb 2, 8:38pm
neo_psy - good call !
tonyrockyhorror,
Feb 2, 9:05pm
Pretty damned awkward to do properly too.
jason18,
Feb 3, 4:25am
Got the runs!No worries!
therafter1,
Feb 3, 10:35am
x1
Just dump it into a 2 litre icecream container or such and add a bit of antifreeze to dilute it a bit, slurry it up to the right consistency with a stick (may require a few more dribbles of antifreeze) and then tip it in lol
But in reality some of the more sensible suggestions above may be more appropriate.
Feb 3, 10:38am
But you still need a funnel of some sort.
bubbagum,
Feb 4, 4:50pm
Thanks for the replies people.much appreciated
grangies,
Dec 8, 4:19am
Squeeze it in with one of those cake icing decorating things.
