Check engine light. What sensors are there or what do i look for in a terrano td27tdi r50
givmassage, Jan 26, 6:34pm
what sensors are there or what do i look for in a terrano td27tdi r50
mugenb20b, Jan 26, 6:38pm
Check engine light = take your car to a garage that has a scanner.
What you can do is, check the air intake hose for splits between the air flow meter and turbo charger, very common. Don't just visually check it, squeeze it and look for splits, remove it if you have to.
dmoney73, Jan 26, 6:58pm
Solenoid in the electronic diesel pump will most likely be the fault. Real common on R50 diesel terranos.
givmassage, Jan 26, 9:20pm
its real random on a bit then off for a while .on.off.-
mugenb20b, Nov 3, 7:46pm
Are there any split air intake hoses!
