Steering wheel play in vt commodore
mcholden1, Dec 17, 10:42am
i failed my wof to day as my steering wheel has excessive play left right and up down im assuming it is the upper bearing in the column the inspector told me it was a common fault in the early vt. so how hard is it to fix the bearing as ill be doing it myself
ceebee2, Dec 17, 12:30pm
There is an upper plastic bush that stops that play and is ok to do if you have the correct gear.steering puller etc. If it has SRS airbag then don't touch it but take to a reputable garage. Cannot remember if that model has the SRS a/b.
mcholden1, Dec 17, 12:58pm
yea it has a air bag so what should i do and how much will it cost
mcholden1, Dec 17, 1:32pm
where can i get this plastic bush im pretty confident in doing it got a workshop manual handy and the right tools
icemans1, Dec 17, 1:37pm
i've got a VT and got a workshop manual, but i wouldn't p!$$ around with it because of the airbag
mcholden1, Dec 17, 1:50pm
bugger mmmm
icemans1, Dec 17, 1:53pm
better to be safe than sorry mate.
mcholden1, Dec 17, 2:00pm
yea thats true so how much will it cost me
mcholden1, Dec 17, 2:02pm
at a mechanics
mcholden1, Dec 17, 2:03pm
mcholden1, Jun 24, 8:11am
mmmmmmmmmmmmmm so i took my car to a garage today to test the play in my steering wheel they had a good look at it and feel of it and they said that my steering wheel was perfectly fine so sweet as took it back to the testing station and the guy told me that the movement in the steering is not normal so what gives mabs ill just get a wof somewhere else
