'98 AU Falcon horn
s.rolly, Dec 29, 8:58pm
Whereabouts would I find the relay for the horn!
bevharris1938, Dec 29, 9:02pm
repco ! Supercheap ! ford dealer ! Wreakers !
jono2912, Dec 29, 9:14pm
I think OP might mean in the car.
jasongroves, Dec 29, 9:21pm
Under the bonnet.
If location isnt obvious, get someone to press the horn button while you listen for it clicking.
s.rolly, Dec 29, 9:24pm
What if it doesn't even make a clicking noise!Does that mean it's something more serious!
jono2912, Dec 29, 9:25pm
Checked the fuse!
s.rolly, Dec 29, 9:44pm
Yeh, fuse is fine.
s.rolly, Dec 29, 9:45pm
.air horns btw, if that makes a difference.
jono2912, Dec 29, 9:51pm
If someone can tell you the location of the relay (I can't off the top of my head), check there is power coming to it (when horn is pressed), and check the relay my putting power through it.
jasongroves, Dec 29, 10:03pm
Check the earth.
Could be self earthed (mounting point acts as earth) or may have a separate wire.
If after-market, are they running off the factory button/switch!
If possible, try running 12v straight to the horn from the battery to make sure its not the horn itself. A pretty simple way to rule one thing out.
jono2912, Dec 29, 10:29pm
Oh yeah, the switch.
henderson_guy, Dec 30, 4:31am
Relay should be pretty close to the compressor. Can you track the wires from the compressor, back!
s.rolly, Dec 30, 10:36am
Again, how!lol sorry.Knew I shoulda taken Mechanics instead of Hospitality!
kingfisher21, Dec 30, 1:46pm
Relay is in the fuse box, right hand front guard by the battery.
rellerion, Dec 30, 6:18pm
what exactly is wrong with your horn!
bjdw, Dec 30, 6:21pm
Whoever put the horn in coulda put the relay anywhere, not necesarily (sp) where he should have.It could be anywhere between the compressor and the button.
s.rolly, Jul 24, 3:04am
It just doesn't go, not even clicking when the button pressed.
@kingfisher, thanks will have a nosey there tomorrow.
