I have a Nissan Primera and its been playing up big time, We had the transmisson replaced in April Last year and a few months later it satarted playing up. basically what happens is it feels like there is a blockage the car will kind of loose power then all of a sudden it gets a burst of power. It often cuts out at traffic lights and kind of shudders really bad. We have had it looked at again by the people who replaced the transmision and they reckon its not the transmision. We are taking it to nissan service center next week hoping they can sort it and its not going to cost a fortune, just wondering if anyone has had this problem before.
jono2912,
Feb 19, 8:15pm
What have you checked!
jvsammut,
Feb 19, 8:20pm
We took it to a mehanic he told us to try a few things whih we have done but sorry my partner did it so I am not sure exactly what he has done, I think he changed some leads, we have been told it might me a co2 sensor or another sensor on the exhaust but the people who I am taking it to on Tue dont reckon its that.
jason18,
Feb 19, 8:27pm
CVT or normal trans!
jason18,
Feb 19, 8:28pm
Also Is it a SR20/18DE model or a QG Engine!
jvsammut,
Feb 19, 8:45pm
its a CVT does sr20 sound right!
jvsammut,
Feb 19, 8:46pm
Duh just saw the comment above mentioning sr20 lol
mechnificent,
Feb 19, 9:04pm
Have you tried changing the fuel filter! That would be a good and cheap thing to try.
cypherboy,
Feb 19, 9:40pm
New! Second Hand! Reconditioned! Rebuilt!
jvsammut,
Feb 19, 9:55pm
reconditioned
jockflaws,
Feb 19, 10:08pm
check the airfilter. if thats blocked, the computer causes crazy things to happen to the auto
jvsammut,
Feb 19, 10:37pm
Thanks will let my partner know :)
jvsammut,
Feb 20, 2:48pm
Can you please tell me what the afm is :)
ryanm2,
Feb 20, 3:25pm
Air Flow Meter.
mechnificent,
Feb 20, 4:51pm
If you go here. http://codes.rennacs.com/ you can have a read up and hubby should be able to get trouble codes out of the computer. The trouble code may tell you that the air flow meter has a broken wire or is not plugged right in. If there are trouble codes, or even if there are not codes, you should do a standard tune up with plugs, check of the electrical system to check the spark is good and that everything is plugged in correct, and a new fuel filter.
The real/recommended process is to tune it and check it over/inspect for faults, clear the codes(it's in that read) and go for a drive, then check for trouble codes.
1fordluva,
Feb 20, 7:09pm
The vapor vac line out of the rocker cover will cause this too. Did mine a few weeks ago,bloody thing was brilttle and had a hole in it.
jvsammut,
Feb 20, 7:43pm
was your car doing the same thing 1fordluva! My hubby has tried the air flow sensor and that hasnt made any difference.
jvsammut,
Feb 20, 7:46pm
Thansks for that site mechnificent, My cousin is who an auto eletrican has looked at the car and has said that there is no code. That the computer is fine. Arghhhh.
1fordluva,
Feb 21, 2:49am
could be a blocked cat converter in exhaust doing that to.
If car has been run with a K&N Filter excess oiling will coat the Fine Wire on sensor and give untold problems,yours sound familiar to what I had with a Maxima
rubic8,
Feb 21, 5:57am
Had same symptoms in our primera, cleaned air flow sensor made slight difference but after a machinicplugged in his faults code devicethe print out revealed it was the crank angle sensor and coil located in distributor .With new one fitted it runs sweet hope this helps
1fordluva,
Feb 21, 7:07am
Infact fish had a simalar problem with a primera a few weeks back,computer was shagged. That came up with no faults after a couple of checks with thier new ecu scanner. He tried the afm out of mine while I was there,didnt change a thing,plugs,new dizzy and igniter from hazy memory.still no good. Switched ecu out for a second hand one and away she went.
jvsammut,
Feb 21, 9:09am
Rubic8 how muh did it cost you for the parts.Somedays it is worse than others which we cant understand why,
1fordluva,
Feb 21, 9:52am
jvs what year an model of primera! I have a whole 1.8ltr auto sitting at a mates place.
karibakid,
Feb 21, 10:43am
Honda ascotCB3need new brake master cylinderor kit who is the best forpricesthanks jack m
