VE rotary pump timing tool
chris_051, Feb 21, 4:32pm
Anyone know where the DTI timing tool can be bought for these injection pumps, or are diesel injection and turbo shops likely to hire em out!
Or, if anyone has one, would they be willing to part with it one weekend for a box of piss etc.
Cheers.
franc123, Feb 21, 4:50pm
Sykes Pickavant in the UK make them, have a google or else contact whoever distributes their product here.For a one off job you may as well pay someone knowledgeable with the gear to do it for you, a fuel shop is unlikely to hire one out, a local diesel/4x4 specialist might if you ask nicely.
intrade, Feb 21, 4:58pm
what vehicle are we talking here!
chris_051, Feb 21, 6:05pm
I'm a diesel mech so am not paying someone $80/hr to check it cheers lol, none of the stuff we work on is that small (road trucks, nothing smaller than 12 litres, generally), its a dirty old VK Commodore with a Nissan LD28 in it.
mechnificent, Feb 21, 6:15pm
Set ut by ear!
intrade, Feb 22, 7:30am
just had a looka ld 28 seems to have a cover in front of engine if its got a timing belt then it should be easy as to get to run right. you use the ear and the eye-ometer and just rotate the pump a millimimeter like doing a distributor on a petrol. when it smokes white or gray = injecting to late unburned diesel untill it smokes black for the first puffand then clears.normally you can see where a pump was before you just have to be 100% sure the gear side is not a tooth out.
mechnificent, Feb 22, 12:11pm
Yup, mechanics all over the country are doing it as Intrade says. none of us have the tool.
Get it going then trial and error till it starts crisply and runs well. a mill or two at a time.
intrade, Feb 22, 2:06pm
http://asavage.dyndns.org/Nissan/Maxima/FSM_1982/FSM_1982_EF-042_b.jpg
i am hunting the friggen marks for the ld20 right now.
intrade, Feb 22, 2:45pm
have you got it for 89 bluebird VE U11 cant seem to find tdc on gearbox side and partsmaster told me the belt they sell me has no markings on it to align.
I made my own marks and i think i am 1 tooth out on the crank.
intrade, Feb 22, 3:36pm
ummm i dont see the injector pump its a 2.0 diesel ld20 type 2.
mechnificent, Feb 22, 3:38pm
Oh, post #9 is LD20
intrade, Feb 22, 3:42pm
there is 2 ld20 engines old one and new mk2 has belt go over cam crank and ip pump just like toyota . i think post 9 is the old engine with crank to ip belt !
intrade, Feb 22, 3:49pm
thanks will see if i can get a belt tomorrowwith markings . I am almost sure i am 1 tooth out on the crank according to my markings, and i want to fit a new belt as i seen a few strings exposed on some of the notches on the belt that is on it.cant be stuffed to see if it is a tooth out untill i got a new belt.
mechnificent, Feb 22, 3:52pm
If you have broadband Intrade, I'll mail you the software. 490Mbs.
intrade, Feb 22, 3:55pm
yea got bb but dont know ifyou can male a large file like that
mechnificent, Feb 22, 4:01pm
Well I'll post it online and tell you where to download it from if you let me know your mail.
intrade, May 15, 6:07am
just inquire for my fiat parts.
