Holden Rear Tyres Wearing
zena1, Mar 2, 7:16pm
5th set of rear tyres on my V6 holden sedan from brand new only done total 175 kms Alignments doneWHAT IS GOING ON HERE!
pettal, Mar 2, 7:17pm
Year,Model etc !.
zena1, Mar 2, 7:21pm
2006 SV6
chito, Mar 2, 7:24pm
Suspension!
franc123, Mar 2, 7:25pm
probably a combo of insufficient rotation and over zealous rear camber, VT upwards models were well known for it.
vr4_legnum, Mar 2, 7:26pm
is the car lowered! it might be best to get a camber kit.
johnf_456, Mar 2, 7:29pm
VT onwards its common, I see it often.
zena1, Mar 2, 7:30pm
Old man driver, mainly open road driving, pressures good last alignment I asked to them to do whatever they could to help me. I have spoken to others and Tyre guys they say typical issue. is it! if yes I am sorry i bought it!
berg, Mar 2, 7:31pm
Camber adjusting bushes are available for these. They improve rear tyre life hugely. Try http://www.nolathane.com.au/catalogue.php
The kit is listed here
berg, Mar 2, 7:32pm
Available from Repco
vr4_legnum, Mar 2, 7:34pm
what pressures do you run! is it on 235/45/17s! and band of tyres have you been useing!
il seen more few holden with the same issue. dont alot can been done with buying camber kits/ camber adjusting bushes
falcons have the same issue
vtecintegra, Mar 2, 7:43pm
I'd love to get 35,000kms from a set of rears on my much lighter weight car
zena1, Mar 2, 7:43pm
28psi 2345z17 toyos
johnf_456, Mar 2, 7:45pm
Why such a low psi!
berg, Mar 2, 7:45pm
Have 55000kms on my VZ ute with the camber adjusting rear bushes. Tyres have just passed another WOF so may be well worth the look
pandai, Mar 2, 7:45pm
28 sounds awfully low
zena1, Mar 2, 7:54pm
Ill check tomorrow could be higher
vr4_legnum, Mar 2, 8:01pm
if your done 175kms in your holden and only replace 5 sets of tyres, i think you doing pretty good with wear. but your pressures are way to low, should be at least 38psi all around. also maybe look at getting tyre what is more harder compound then the toyo
clark20, Mar 2, 9:01pm
Sh!t, i would love to get 20,000km out of my 20"s, at $500 each. Oh well my back up set is 19"s.
r15, Mar 2, 9:11pm
i too would love to get 35,000kms from my tyres. so far the best ive ever got is around 20,000 and my work car only got 8000!
paull, Mar 2, 9:31pm
camber kit mate, prob solved
big.b-lil.c, Mar 3, 10:40am
dam i get 100,000 out of the 4x4 glad i dont own a commie. vr4 may have hit it on the head if using high performance tires they will wear faster. get a good quality touring or commuter type
dent, Mar 3, 4:35pm
you havent told us how they are wearing. Are they wearining evenly, the edges or the centre.
zena1, Mar 3, 7:07pm
pressure 38psi, tyres wear on outer edge then rapidly across tread towards centre. What are better wearing tyres! can I mix with the new rear Toyos to front and buy a couple of harder wearing tryes on rear willing to sacrifice handling> I dont drive hard and mostly long haul I think I should get much more Kms.I will fit camber bushes if that dont work I will by a Toyota or Ford.
smac, Mar 4, 7:07am
The bit of info missing from this thread is, what would 'normal' wear on this car be!
