Any recommendations for the type of glue to use when fitting a head lining in a car Thanks
quickstitch,
Mar 7, 8:18pm
what type of headlining ! A suspended one (ie, it is hung on steel bows) or a modern type fabric stuck onto a backing board ! i use ados F2 around the edges of a suspended type, and bostic spray glue for the latter. Bostic has a better heat range, it doesn't fail under very high tempertures.
tractor9,
Mar 8, 7:16pm
Thanks Quick. It's a suspended one with the steel bows.
ontwowheels,
Mar 9, 3:35pm
ados F3, it is a variation of F2 designed for vertical and upside down surfaces. Ie doesnt drip, it is easier to spread on I find.
socram,
Jul 4, 1:42am
Quickstitch - if you are still around on this thread. Have you any experience of installing a headlining UNDER a roll cage!The cage means that using the original hoops is impossible, but there is bags of headroom, so wondering if covering the cage is a viable option!
