Ute question
danni_2254, Mar 12, 9:32pm
Can you fail a wof on rust in the tray! Is it deemed structual!
r15, Mar 12, 9:37pm
they dont seem to fail.though i dont know the actual law on it
danni_2254, Mar 12, 9:38pm
Cause they arnt actually attached to the cab, i'd imagine it'll be algood as long as it doesnt pose a safety risk! (i.e rust falling off above wheel arches ect)
bubbles52, Mar 13, 12:56am
yes, if the tray isn't removable, eg. kingswood or any falcon before the AU model
mrfxit, Mar 13, 6:41am
Rust for a fail would at least be for .
Flaking rust
Mounting points
Tail/side gate attachments
Mudguards & mounting points
Tail/side gates
Light mounting points
Anything jaggered
External holes (fingers cought in the hole on the way past)
Anything loose
Any holes in the flat part of the deck would be an instant fail IF you were stupid enough to not cover them.
I think it's covered under the same rules as truck decks/trailers etc
danni_2254, Mar 13, 7:27pm
So then welding repairs wouldn't need cert ect!
danni_2254, Mar 13, 7:33pm
And does that include utes with removable trays! Otherwise could just go in with no tray!
mrfxit, Mar 13, 7:43pm
The removable tray would still have to comply as well as the attachments used.
Basicly if it's not fitted at the time of inspection, then it can't be checked . BUT . if a roadside inspection is done WITH a faulty removable tray fitted,or you are invloved in an accident AND perticulery where the condition of the tray could be a cause of THAT accident,. then you would be in the P ooooooop
mrfxit, Mar 13, 7:44pm
probably not .BUT only as long as it is used DOMESTICLY & not for hire.
danni_2254, Mar 13, 7:49pm
Yea, looks like ill be ok then
unideck, Jul 16, 4:42pm
Danni, nothing stopping you doing the welding yourself unless its a COF vehicle and is a structural section to be welded. Private vehicles are wide open for you to weld up yourself unless you are building replacement mounts say for certified engine transplant and or suspension lifting etc. As for patching your deck area just go for it.
