first off the the engine is a ZC 1600cc twin cam and my problem is i can't work out where the middle hose on the manifold plenm goes on my one there are three pipes in a row first one to the thottle body and third on to the fuel presurre reg. please help car has to be running all sweet by sunday night
jjc09,
Mar 13, 8:53am
thanks jezz have tracked in so far down to the under side of the manifold but from there i cant find anywhere it could go
jasongroves,
Mar 13, 8:52pm
Post some pics.
ginga4lyfe,
Mar 13, 11:22pm
from memory it goes to the charcoal canister if it has one, you can pretty much block it off, its not really needed unless the car is not doing to well with out it
jjc09,
Mar 14, 3:10pm
so far i have been playing with it and from what i can tell it controls some sort of throttle advance because it moves a diafram on the throttle body and when you block it of the revs drop down to 700ish rpm
lugee,
Mar 14, 3:39pm
If I am correct you are talking about the PCV hose. This should run down through a tab on the intake manifold pipes, where the PCV valve is located, and then run down to the breather box on the back of the block
jjc09,
Mar 14, 5:50pm
ok i think i no the box your talking about is it located about mid way on the block and is reasonabley large
for_an_angel,
Mar 14, 5:55pm
Any vac hose on that side of the throttle blade will affect idle when blocked and unblocked. As it's an air leak when unblocked.
jjc09,
Mar 14, 6:14pm
oh ok
jjc09,
Jul 21, 10:07pm
problem solved thank you all she running sweet now
