Can you put power steering into a 1988 honda civic
blayke-m,
May 20, 7:13am
can you put a power steering set up from a more modern civic in a 1988 honda civic that doesnt have power steering!
ct9a,
May 20, 7:31am
yes ef7,ef9 will swap in,colom,rack.inner rack ends,tie rods
_peas,
May 20, 5:56pm
Or buy one with PS.
grangies,
May 20, 6:23pm
Goodness Gracious me.
jason18,
May 20, 7:01pm
Why tho. Just grow some muscle ;)
May 20, 7:15pm
Exactly, the steering in '88 Civics isn't heavy at all, provided tyre pressures are correct.
hijacka,
May 20, 7:34pm
This may come as a surprise to most, but a DA integra subframe steering rack,lines,pump etc will bolt straight up to a ef, just find One with the same series engine in your case D/ZC and theres plenty more DA integras than civics to pick fromi rekon. But on another note i would think a non powersteer civic would be more sort after than one with powersteering, because it would be more economical.
johnf_456,
May 20, 7:35pm
Heck if you think a civic is hard, try driving much older and much larger vehicles. Grow some muscles, right on mugen20b and jason18.
blayke-m,
May 20, 8:41pm
i was only inquiring on behalf of my elderly grandmother who has a 1988 honda civic and is struggling to drive it but does not want to part with it so i was going to put a power steering set up in for her so she doesnt have to part with her car.
NZTools,
May 20, 8:48pm
Once it is converted, it will require certification. ($400 ish)
sr2,
May 20, 8:51pm
I hear where you're coming from, I helped fitpower steering to a mates elderly Mums Falcon some years back, wasn??
a18a,
May 20, 8:59pm
you could probably find someone without much effort who wants a manual steering rack and tell them they can have it if they convert your car to power steering
mrfxit,
May 21, 6:48am
DING .^ ^
ct9a,
May 21, 6:55am
if all swapped and OE who will ever even know!
mrfxit,
May 21, 6:59am
Insurence could be the only hassle, but if done really well with NO SIGN of the alteration, TOTAL factory bolt in job with NO fabrication of any sort & working correctly. then yea why not.
desmodave,
May 21, 7:23am
Good on ya for looking after your Grandmother.
shuddupowh,
May 21, 8:26am
Since when. If you modify a car in this way without increasing power (eg no turbo) and no structural changes then there is no need. Just like doing a manual conversion to an auto - no cert required if no cutting etc is done. Use all OE parts and your fine.
May 21, 10:23am
Get her a new car with p/s and auto trans.
vtecintegra,
May 21, 10:31am
You could try posting this on the http://nzhondas.com forums and see if anyone would like to swap.
Manual racks are always in demand, however most people doing to power-manual conversion are looking for the manual EF9 rack as it has a faster ratio.Still worth a try though.
blayke-m,
Mar 16, 8:09pm
thanks for the advise we ended up getting her a 1995 ford telstar with power steering and an auto trans it worked out cheaper then doing the mods
