What psi is best for low profile tyres?
weezal, Jan 25, 11:22am
All I can see is max load 51 psi and I know its not that and I know its less than normal car tyre cos of the less area to fill with air. Suggesstions!
pollymay, Jan 25, 11:25am
On a blue car, about three fiddy
Red ones it's best to just give up now, too heavy
skyline_guy_r34, Jan 25, 11:54am
Doesnt matter how much area there is to fill. psi is a measure of pressure. Pounds per square inch. Doesnt matter if your filling a car tyre or a truck tyre. 36 psi is still 36 psi.
Im assuming you have a 235/35/18 or something like that. When i run 55 or 45 profile i use 38psi. When i had 35 profile i liked to use 40-42 psi.
richardmayes, Jan 25, 12:17pm
No.
MORE pressure is required with lower profiles.
jason18, Jan 25, 12:18pm
I run mine at 40. 235/45r17
thunderbolt, Jan 25, 12:25pm
I run mine at 40. 245/45r17
weezal, Jan 25, 12:46pm
Cheers guys. Sorry I meant to say more but I didn't think it was up2 51.
vr4_legnum, Jan 25, 3:46pm
I run mine at 40 psi. 225/40r18
fordcrzy, Jan 25, 3:58pm
36psi
ninja_man, Jan 25, 4:14pm
anywhere between 36 and 40psi will do just fine
alimac1, Jan 25, 7:38pm
40 psi. 215/45/17
clark20, Jan 25, 8:47pm
38psi245/40/19 and same for my 245/35/20
a.woodrow, Jan 25, 9:13pm
Not much to add. but 38-40 is good. if you notice wear on the outside edges of your tyres, put in an extra couple of psi, if theres wear around the middle, drop it a few psi. if its wearing good, leave it alone :)
moosie_21, Nov 1, 11:46pm
40 psi is good, run mine at that. 51 psi would be for carrying the maximum load allowed by the tyre (also on the outer wall).
