can water, but have never seen green coolant come out before!- the car has to many covers to check the radiator- other than the cap and overflow- so before I look stupid taking it to the mechanic- thought I would ask here first:) t.i.a
jason18,
Jan 25, 4:51pm
No aircon wont drip coolant. Might be a leak somewhere
Jan 25, 4:53pm
No coolant should leak, ever. A/C has nothing to do with it.
pup2,
Jan 25, 5:01pm
Air con has a green dye in it. Used for finding leaks, with a uv light if only a small leak. Could be either rad fluid or air con. If it is air con, it will not be working now. Green dye from air con will also have an oil feel to it.
maccado,
Jan 25, 5:05pm
yup thanks a trip to the mechanic- was alot of coolant so wouldnt be dye I wouldnt think, Cheers:)
tonyrockyhorror,
Jan 25, 6:01pm
No, but the coolant could be leaking from the heater core and running out via the evaporator compartment where the condensate drain comes from.
fordcrzy,
Jan 25, 6:09pm
if its coolant then dont drive it anywhere until you check the coolant level.
no point in cooking your engine on the way to the garage
Oct 31, 10:15am
maccadu--a PROPPERLYworking ac with no leaks willdrip clear water. Anything that is a color is reason for concern. The guys above have it covered off 1)DONT drive untill you check you radiator water level -and do drive to a mechanic/radiator specialist DIRECTLY
