What tools to buy for DIY work on a motorbike?
jock_in_nz, Jun 27, 5:07pm
Apart from the basic little set that came with my bike, I have no tools to work on it.I'm wanting buy some so I can do the basic stuff like chain adjustment, oil filter, brake pads, etc.So what should I buy and where should I buy it from! Thanks.
ninja_man, Jun 27, 5:16pm
if you have got a bit of money, you should buy something like this: Listing #: 387276711 probably all the tools you will need
mugenb20b, Jun 27, 5:18pm
Ummm.those are not tools, they are toys made in China.
berg, Jun 27, 5:18pm
Chain adjustment depends on the bike but I always like to torque the rear axle afterwards with a good torque wrench. Other than that and if it's a Jappa, good set of screwdrivers, metric allen keys, 1/4 drive deep socket set with a good long extension, spanners, 8mm, 10mm, 12mm, 14mm, 17mm, 19mm, 22mm and maybe if needed a 24. A good half inch drive, long handle ratchet with 17, 19, 22 and 24 sockets. A multi meter and pliers are also handy.
berg, Jun 27, 5:21pm
For general "private" bike work, I would suggest maybe Repco branded tools (Sidchrome copy) or even Genuis. You shouldn't need the top of the line stuff but buy the best you can afford.
jock_in_nz, Jun 27, 5:28pm
Yeah was thinking a torque wrench is a must. Just trying to decide if I should buy a made up set or individual tools and build a set. For a socket set, does 1/2" or 1/4" make much of a difference!
mugenb20b, Jun 27, 5:29pm
Get all three 1/4, 3/8 and 1/2 drive.
berg, Jun 27, 5:35pm
For bikes I find I use the 1/2 for the big stuff, axles, sprockets etc then use the 1/4 for most other things as they are usually 8mm or 10mm.
jock_in_nz, Jun 27, 5:44pm
Thanks guys. Is it worth buy off here or from SCA, Repco, Mitre 10!
m16d, Jun 27, 5:45pm
Well for a start get a good set of allen keys.
Go to a tool shop, not the $2 shop.
berg, Jun 27, 5:51pm
Stay away from the Supercheap, Mitre 10 type stuff. Try Repco, BNT or a good engineering shop. Also see if you have a Sulco tool dealer in town. They sell several brands usually to the "trade".
ceebee2, Jun 27, 7:35pm
Basic ring / open enders you will need are
6,8,10,12,14,17,19mm
Sockets as above, My advice is do not buy cheap crap or you will ruin the nuts n bolts.
A very essential tool is an impact driver.
Cheers CeeBee
bubbles52, Jun 27, 8:06pm
Agree, these are great kits, high quality too, i have one that i use to take to wrecking yards to get parts off
jock_in_nz, Jun 27, 8:10pm
Thanks guys for the advice. It'll be tool shopping time coming up this weekend then.
fryan1962, Jun 27, 8:43pm
if your bike doesn't have centre stand.you will need a lifting frame.not sure of the name of it, but so useful for adjusting chain
klrider, Jun 28, 5:58am
first thing you need is a manual
321mat, Jun 28, 12:15pm
Sidchrome, and Wurth make the best.
Stanley are not too bad.
But, anything that's not drop forged vanadium is just a waste of time and money.
jock_in_nz, Jun 28, 6:30pm
I'll take you up on that offer kazbanz. How do I get a hold of you!
r15, Jun 28, 10:58pm
T bars.
the ultimate bike tool
desmodave, Jun 29, 6:59am
miller cars rings a bell.Just buy a reliable italian bike and ya wont need bugger all tools
zoltec45, Jun 29, 7:38am
I wouldnt be without my powerbuilt 1/2" socket set and ring spanner set. Only broken one ratchet piece in 3 years and they have a lifetime warranty on tools so just took it in and swapped it there and then.
Try The Toolshed for good branded tools
desmodave, Jun 29, 9:09am
Well mine have all got me home under thier own power for the last 25 years so i would call that reliable.
marte, Aug 10, 1:19pm
Impact driver to loosen screws if they are a bit tight.
You end up rounding them off if they are tight & you use only a screwdriver.
You don't have to bash it, just let it seat in the screwhead & tap it.
Or the #8 wire impact driver.
(you seat the screwdriver, turn it anticlockwaise a bit so it rises out of the screwhead, then bash the screwdriver with a hammer.)
OK OK! I know its called a "Screw turner"
