1976 corolla
payntr, Jun 24, 8:01pm
1200cc can some one tell me.when i remove the radiator cap, the water level is correct,with the radiator cap replaced and motor warms up the overflow water resevoir cap when removed nearly blows it out of your hand(not the radiator cap) could the thermostat be faulty,or blown head gasket.there is no water in oil.oil is clean.
snoopy221, Jun 24, 8:06pm
Unfortunately and sadly even an old 1976 corolla had an ALUMINIUM cyl head on a STEEL engine block.
And water is not antifreeze/corrision inhibitor between disimilar metals
So um yep combustion pressure in cooling sytem and no antifreeze=
Blown head gasket-corroded cyl head.
Repariable though.
richardmayes, Jun 24, 8:07pm
Pressure cap on radiator isn't sealing properly!
payntr, Jun 24, 8:10pm
it has always had antifreeze added to water.
new pressure cap.
payntr, Jun 24, 8:11pm
sry it has a new pressure cap.
payntr, Jun 24, 8:13pm
so you think a new motor/recondition if so what approx cost !
jason18, Jun 24, 8:15pm
Sounds like my 77 corolla it had blown head gasket. Easy as to do tho.
jason18, Jun 24, 8:17pm
Its a 3k motor I guess. I would take head off get it skimmed and crack tested fit new gasket and should be sweet
payntr, Jun 24, 8:24pm
many thanks.
jason18, Jul 23, 5:11am
But do take to mechanic just to get pressure test done to make sure it is head gasket but sounds pretty similar
