What's the retail on a cheap pair of mud grips?
bjdw, Jun 24, 8:14am
14/195.
Oh f*ck, my truck, is stuck.
sctoyota, Jun 24, 8:39am
Maxxis do buckshot they retail for bout$230 each
skin1235, Jun 24, 12:15pm
sounds serious, you were asking re diff as well so heres a couple of questions
is it still stuck ( and you cannot get either to it or to it with another vehicle to pull it out )
suggestions - borrow a set of snow chains , jack the drives up fit the chains and pack the grooves with graveletc ( branches will work but they can be almost as bad as the original mud if not done right ) then jack the others up and pack under them too
do the rims have slots in them - you can actually pull a tow rope through the slots loop over the tread and back through the slots all the way around and make a set of grips like that
it does happen to others too, I've had a hilux 4wd on her belly and spent a full day with jacks and chains etc, and got her out without having to drag the crawler in to get her - helps if you've got a chainsaw and a bit of kit though
bjdw, Jul 20, 9:54am
Thanks for the advice guys but the neighbours 4x4 got it out.Cheers.
