currently running a carbed 202 with an LPG system. im upgrading the engine to something fuel injected. what do i need to change in order to run it! can someone reccomend a specialist who can do a good job. dont care for cost, i just want it done once and done right
guider1,
Jun 11, 6:37pm
Is this your van!
Jun 11, 6:39pm
you would want a different lpg system on injected you want lpg injection where they drill new holes for gas injectors and then it injects gas instead of dumping it in the intake . lpg injection is within 2% as efficient as petrol
toxicgreen.,
Jun 11, 6:48pm
I know the last version of 202 did actually get an injected manifold and ECU. You might be able to locate one if you seach.Also had a mate with a V6 ex cop car,injecters were not running and cops had that just running LPG.I,d stick with wat you,ve got and just tune an time it for the best you can get on LPG.Wen occasionally on petrol it wont be tuned the best but just tri an stay on LPG. The differance between the two fuels is timing, so time it for LPG
jezz43,
Jun 1, 6:18am
yes its my van, i dont like the 202, so its coming out. trimatic gearbox is a bag of crap and i want to upgrade it all. indecisive on engines at the moment, tossing up between 350 chev, 308 holden, VN 3.8 V6 holden or a twincam straight 6 of some variety. the V8s will be carbed but if i go with one of the other engines it will be injected. so im weighing up cost/effectiveness pretty much
