Light comes on. Coolant is full. Could it be a sensor!
bae13,
Jun 8, 5:57pm
most likely the sensor in the overflow, cant remember if you join the wires together or just unplug it, just try it and see think you need to turn the key off then back on to clear the light
nave12,
Jun 8, 7:06pm
may just need a drink(top up) or If the coolant level is right, the sensor could need replacing. The float can get a leak and fill with coolant making the sensor useless.
grangies,
Jun 8, 7:10pm
Just ignore the light if it's only a sensor problem.
jason18,
Jun 8, 7:22pm
Yeah just bright at night and mate wants to get rid of the light from showing. Coolant full. Will check float before replacing sensor. Thanks guys. Mate just bought it tonight Bloody tidy 1 owner
crzyhrse,
May 22, 3:46am
Sometimes just a clean of the reed switch will suffice. But sometimes the float has disintegrated.
Open circuit makes them flash.
