Toyota Surf Jap import 1KZ-TE foaming radiator
sturmiearcher, Jan 18, 8:08pm
A mate truck.Had cracked head so he a new head fitted, new radiator, new cap and thermostat. Now has very fine white foaming and forces coolant into overflow reservoir. Anybody got ideas of the foaming ! . cleaning chemical maybe !. will be doing several flushes to try improve maybe
mugenb20b, Jan 18, 8:20pm
1. Did you torque the cylinder head bolts correctly!
2. Did you use new head bolts!
3. Change the viscous hub on the radiator fan.
4. Take the car to a garage and ask them to carry out a TK head check.
sturmiearcher, Jan 18, 8:24pm
Hey cheers for your reply, I didn't do the job so not sure what went on, I do recall the owner saying there was new head studs in the head kit.
It does the foaming from stone cold too.
gadgit3, Jan 19, 5:09am
Cracked block.
sturmiearcher, Jan 19, 5:46pm
hey I have just found out the dick topped up the overflow bottle with windscreen washer fluid. he put it in the wrong hole !
gammelvind, Jan 19, 5:50pm
DUH!
sturmiearcher, Jan 19, 5:53pm
DUH alright ! some mothers do hav em
johnf_456, Jan 19, 7:10pm
Dam, I have seen that one often after customer getting the guy at the service station to top up there water.
mrfxit, Jan 19, 7:51pm
Also very common appearance with a water pump seal leak
r15, Oct 7, 1:01pm
Has he replaced or correctly adjusted his viscous!If not he might as well order another head now.
