Weird noise in Rav 4
ginga4lyfe, Jun 3, 1:28pm
maybe check to see if the drive shafts are in correctly, or if the caliper carrier or caliper is tighened down right, something may be binding and slipping!
m16d, Jun 3, 1:33pm
Yer got a crook rubber bush in the suspension somewhere.!
cocabowla, Jun 3, 2:16pm
loose mounting bolts on bullbar !
paul271, Jun 3, 2:38pm
Cvs are common on these. Especially inners, check to see if there is any grooves on the inside of the inner joints. Had a few do that to me. Also the rear diff mounts are common for making a thump too, usually when going from 1st to reverse.
panicky, Jun 3, 3:11pm
Have you had the brake discs machined recently!
toyboy3, Jun 3, 3:23pm
check the tyre sizesmake sure all the same
mrfxit, Jun 3, 3:29pm
LOL na no worrys buddy, thats just the noise the engine makes when it's running ;-)
mrfxit, Jun 3, 3:31pm
Will it "do it" in reverse!
mrfxit, Jun 3, 3:33pm
Again . braking hard during a LEFT or RIGHT turn or ONLY in a straight line .
Oh & auto or manual. will it do it in gear/ out of gear or no difference
mrfxit, Jun 3, 4:15pm
Back on the hoist to do a fine check for suspension wear marks.
Clearly somethings moving that shouldn't be so stands to reason there "should" be some wear/rub marks were there shouldn't be
ladatrouble, Jun 3, 4:42pm
Check the rear diff mounts.front and rear.
for_an_angel, Jun 3, 5:56pm
Rear diff mounts would be a standard guess or rear sway bar bushes/links. Another issue )common( would be the trans fluid has been changed and someone has used dextron 2 or3 (standed auto fluid) but you need to run Toyota type t4 or Castrol transmax J
hondalova, Jun 3, 5:57pm
maybe the ex in the boot, rolling around.
zooki007, Jun 3, 6:03pm
Front wheel bearing! Loosen the hub nut very slightly and check for play in bearing. If there is lots of play the hub will be worn. Just done 1 in our workshop today.
goldilocks64, Jun 3, 6:05pm
its the diff mount theres two of them and the front top mount will be bugged
zephyrheaven, Jun 3, 6:06pm
Easy to replicate handbrake on into drive & sit there dropping the throttle - rear diff mounts most likely but interesting to see if it isnt
zooki007, Jun 3, 6:07pm
Even with new diff mounts they knock.
for_an_angel, Jun 3, 6:13pm
+1 lol bloody common as needing a dump in the morning
fordcrzy, Jun 3, 6:19pm
spray some silicon spray or crc on the suspension strutts where the springs seat on the strutts top and bottom.it could be the springs binding on the seats as they move.
zephyrheaven, Jun 3, 6:20pm
True true - I never fixed my nieces one ha ha, maybe Kaz has it now lol
fordcrzy, Jun 3, 6:22pm
for_an_angel, Jun 3, 6:33pm
Nah no help to be had there mate. the Rav in question there is a 06 model and v6 (not available in NZ) but the fault is the intermediate steering shaft (field fix) Recall in 2007 UK and 2009 NZ 4cyl models
fordcrzy, Jun 3, 6:40pm
the rav 4 site may be of some help though.
glennalan, Jun 3, 6:45pm
I had a similar noise in an old toyota Corona, the diff bearing came loose in housing and rotated when load taken off ie under deceleration. Sit on axle stand to test.
mrfxit, Jun 5, 5:46am
Is it fixed yet
