Rav 4 air con no go
motorboy2011, Sep 15, 3:14am
Air con on the rav isn't going, the system has pressure so I'm assuming it's the actual air con switch or the relay, anyone know where the relay is? I've looked and can't find. All fuses are checked and good too.
franc123, Sep 15, 5:15am
Yes but how much pressure? It might appear to have charge in it but it could be low enough to have tripped the sensing switch. Needs to be confirmed with gauges.
bigfatmat1, Sep 15, 5:47am
Start backwards and check from there. Power at the pump ------> yes = clutch faulty. --------> no check pressure switch and so on and so on
kazbanz, Sep 15, 6:34am
Motorboy. What IS working? Fan? the AC unit? The heater?
WHERE did you check the fuses?
motorboy2011, Sep 15, 7:37am
Checked fuses under dashboard and bonnet. Cooling fan nor Ac clutch engage when turned on. Light on dash switch doesn't come on.
elect70, Jun 26, 1:29pm
too cold to cut in ?
