Car alarm in vw wont stop!
bek83, Jun 2, 7:21am
Please help.was away for a while so had to re-charge battery on my 96 vw when I got back, charged battery and put back into car but now the car alarm wont turn off no matter what I do.please help anyone!
intrade, Jun 2, 7:39am
dont you have the alarm thingy remote! also most alarms have a switch under the dash somwhere to disarm the noise .check on horn it self if it can be turned silent and unplugged. for now.
intrade, Jun 2, 7:41am
ps vwdont come with alarms so it be aftermarket junk that you got.!
johnf_456, Jun 2, 7:43am
Yup thats what the title means a car alarm in a Volkswagen.
bek83, Jun 2, 7:47am
I dont need to use it every day so yes it is a junkee car, but does the trick so thanks anyway for that comment intrade.I do have an alarm remote but that only stops it for 1 a minute or 2. Will check the horn, thanks.
intrade, Jun 2, 7:54am
i said the alarm will be junk like most are. I choped the mongoose crap from my fiat as it was usless as and took me 2 minutes to disarm it with a wire cutter.
intrade, Jun 2, 7:56am
find out what alarm it is and post here somone will know how to stop it bleeping . have you tryed disarming it and then starting up the car ! that should normally disarm it for good unless there is a fault like the crap one i removed.
johnf_456, Jun 2, 8:02am
It may need to be re snyc'd again, any chance you know what model it is! Perhaps ring up a alarm installer or someone that specializes in the alarm you have.
elect70, Apr 30, 3:01am
A hammeror wire cutters !
