Holden Captiva issues
paul271, May 25, 7:17am
Hi all, just got a weird problem on a 2006 Captiva V6. Keeps fouling plugs on the front three cylinders, and causing a misfire. Codes are for a misfire on 2 and 6, no other codes. Have replaced all the plugs, and coils are all firing. Anyone come across this before!
evotime, May 25, 11:03am
Broken rockers!
antwerp87, May 25, 11:17am
Coils may be firing but are they firing propperly! Low Amperage could be your issue! Make sure there all in working peramiters. So check the Resistance on each one.
321mat, May 25, 12:18pm
It's just out of warranty, isn't it!
franc123, Apr 1, 5:06am
Seems a bit bizarre that its only doing it on one bank.If swapping the coils from front to rear doesn't change anything it might be a case of getting it put on a scan tool to see what the O2 sensor readings are doing, and if possible what the injector duration is doing.It may be one or more of the injectors is sticking or not spraying properly, I know it sounds a bit of a left field suggestion but have seen this before on another vehicle that had similar symptoms.
