I want to install a light beeper in our 85 corolla as the Mrs keeps leaving the lights on- how could I do this! I figure If i get a beeper from a wrecked car I just need to figure out how to wire it in. Has anyone done this!
ontwowheels,
May 20, 10:29pm
and can anyone recommend a good central locking kit!
jono2912,
May 20, 10:34pm
Go to Jaycar and get a polarity sensitive buzzer.
Wire a positive to the headlight, and the negative to ignition switch
jono2912,
May 20, 10:36pm
Have wired a cheap one up from here, they aren't hard and the cheap one hasn't failed me yet.
ontwowheels,
May 20, 10:51pm
Awesome thanks Jono
ontwowheels,
May 22, 8:38am
just thinking about this polarity sensitive buzzer- how does it work! Obviously i want a beep or buzz when the lights are on but key is off. But then it needs to go off either when the doors are shut, or the key is removed. i am guessing the doors shut option would be easier. It seems to me that it would need more than 2 wires. Because the one that senses if the ignition is off will not bea closed circuit when the buzz is needed. requiring a second earth. If that makes sense
What I suggested would only work if key off, and headlights on.
