Cheap place in welly to get a few tires changed
n1smo_gtir, May 16, 10:48pm
from one mag to another so all 4 mags are the same. anyone can recommend any from previous experience! tony's tires far from cheap, i know cos i used to work there but all my old collegues left so no contacts.
n1smo_gtir, May 16, 10:52pm
also is there any rules for WOF to say that the directionals tires have to be in the front and non directionals in the rear to pass! as long as same type is on the same axis! just that atm i have 2 directionals in the rear and 2 non directions in front. cheers
kcf, May 17, 6:25am
You're fine.As you say, same on the same axle is required.Doesn't matter if that is the front or rear for directionals.
johnf_456, May 17, 9:00am
For wof's all you need is the same on the same axle (front or back), so 2 directional on the front a and they also need to be pointed in the right direction to work as they should. There will be an arrow on the side wall.
n1smo_gtir, Mar 21, 10:15am
sweet, cheers guys.:) just gotta replace my brake pads and i should be sweet.
