Nissan Primera P10 - Any good?
pentium4, May 17, 6:32pm
Hey guys,
My mates got a 1.8l 1992 p10 primera he will let go for 1500 it has a busted crankshaft oil seal which is reflected in the price. it is automatic and seems to go well need to know a few things
1. Are there any common probs with these!
2. Are they reliable
3. How hard would that oil leak be to fix
4. apparently they are chain driven! (sr18de is the engine)
mugenb20b, May 17, 6:37pm
1. Front upper suspension arms, engine rattle on start up, seized cams due to lack of servicing (broken timing chains)
2. Depends how they were looked after, but generally they're OK.
3. Depends which crankshaft oil seal you're talking about. Front or rear!
4. So! That's not always an advantage.
pentium4, May 17, 6:40pm
its done 193000km serviced reguarly and it is the front crankshaft seal
mugenb20b, May 17, 6:41pm
Never done one, but shouldn't take more than an hour to fix.
franc123, May 17, 6:52pm
You need to bear in mind they are an old car now, it's unrealistic to expect a trouble free run out of one, it WILL regularly cost to keep going and getting through WOF's etc.Common problems, yes cam and lifter wear due to oil sludging, idle control valves die, governor gears in the trans strip and it won't change gear, luckily its not too hard to repair, suspension wear, fuel pumps will die if filter changes haven't been regular enough, general issues with all body electrics, windows, gauges, door locks, etc, as well as starters and alternators.Best of luck.
johnf_456, May 17, 6:54pm
As above not much different to any other car of that age.
jason18, May 17, 7:03pm
$1500 not that cheap when it still needs work. Offer him $1200.
dasfi, May 17, 7:08pm
i have a p10, which is a great runner you can have for $2000, 2.0l Auto
jono2912, May 17, 10:57pm
I prefer the 2.0 over the 1.8 myself tbh.
jason18, May 18, 5:06am
yeah definately 2lt.
kandjaja, Mar 5, 4:59am
Try and find a 2 litre one for similar money.1.8's are gutless piles.
