Just about cert time for the VH but as it has aftermarket rear springs, when you jack up the rear, the springs come loose. Where can I get shorter shocks from! Cheers
berg,
May 15, 5:28am
Yellow pages. Look for suspension specialist in the Hutt.
skully13,
May 15, 6:17am
Any parts store, Repco, Supercheap, or on here. Monroe, KYB, Pedders etc all make them. You can also get thicker polyurethane spring seats that can help a little bit.
dave653,
May 15, 1:07pm
My HJ has Viva shocks. shorter from the factory and just happens to fit, shock specialist recommended it. Don't waste time and cash buying custom jobbies.
bill-robinson,
May 15, 1:42pm
why not put helper springs in.
hatchback,
May 15, 10:00pm
Thanks guys, lots of good info
im_andrew,
Feb 23, 5:52am
You can cut the lower shock mounts off the diff housing and weld them back on the other way up. Seen this done a few times, could have been factory on an ss or an hsv or something.
