Motorbike firing but not starting? HELP
ride_bmx1, Apr 11, 11:03am
i have a 49cc Honda correos pit bike. it went fine then just died and wont start so i checked spark and its getting spark its 2stroke so checked it has right mixture not that took carb off and cleaned it out and everything seems fine. cant smell petrol on spark plug though! any ideas what could be wrong! it runs for like 2 maybe 3 seconds then dies. also tried playing around with fuel mix screw
flat_white_ltd, Apr 11, 11:08am
( Hey, please don't get p*ssed ). you aren't trying to start it on full choke after it's fired, by any chance.!
ride_bmx1, Apr 11, 11:17am
ok. have drained carb several times cheers
ride_bmx1, Apr 11, 11:19am
fired on no choke
biddy6, Apr 11, 12:17pm
Has it got compression!
kiwi-d, Apr 11, 12:53pm
ARE YOU SURE ITS TWO STROKE!
peril787b1, Apr 11, 1:14pm
When was the last time you cleaned the air filter! If the filter is blocked it won't run
plasticboys, Apr 11, 1:22pm
newspark plug needed if its a 2 stroke some times they look fine but are not
ride_bmx1, Apr 11, 4:21pm
yes has compression, yes is 2stroke! as far as im aware of. airfilter is clean. yeah i was thinking that. have another bike the same and used the plug out of it and still didnt go! so guessing it a fuel problem nut getting fuel from cvarb to piston! maybe!
dasfi, Apr 11, 4:36pm
Bit of start ya Bastard works fine, half a can got mine going last nyt.
keith18, Apr 11, 5:56pm
when did you use it last ! 2 strokes dont like a masson bee nest up the exhaust . i had a 2 stroke pump motor ,would start and then die almost straight away . bees up the exhaust
toxicgreen., Apr 11, 6:29pm
Go over all the basics,petrol,spark,compressio-
n,unsrew phillips under carby, see petrol flow-retighten(if no flow tap bowl housing lightly with hammer ,clean all of plug with toothbrush,an tri starting with no air filter,refit filter before riding.Stand bike on back wheel to let built up oil drain out of exhaust(best done wen motor is hot an fuel tank has run out) dribble 10 mls of petrol down plug hole to help start it.
jmma, Apr 11, 6:31pm
drain tank and carb, start again with fresh fuel
roys351, Apr 11, 6:59pm
sounds like stale petrol to me
40wav, Apr 11, 7:08pm
I dont believe that 'myth'. I got my chainsaw out of the shed after it sat there for over a year with fuel in, gave it a bit of a shake, and it started 2nd pull and ran fine, just like always.
roys351, Apr 11, 7:15pm
my saw wont start after 2 months fresh gas and it starts. if your saw is a husky or sthil it will proberley start fine on stale gas
ml6989, Apr 11, 8:05pm
Poor quality fuel we get dished up, fouled spark plug. I would bet tomorrows bowl of Kornies on it!
cheviot, Apr 11, 8:39pm
Same here with my old 82 honda 500. Sits outside under a tarp since xmas 08 and starts on the 6th kick with the same petrol it's had in since then and I started my old 350 chev after 18 months with the same old fuel.
plasticboys, Apr 12, 2:03am
all l know 90% of all bikes l'v fixed has been the spark plug other thing is a bit of shite stuck in the main jet
lugee, Apr 12, 1:51pm
I started my Honda CRX after it had been stored for 8 years with the same petrol in it.
tekaholics, Apr 13, 12:54pm
hard have to agree it will be the float inside the carby
tekaholics, Oct 24, 12:40am
wow.amazing if only it was about your car
