PLEASE HELP NEED Ford motor knowledge
xacoon, Mar 18, 7:29pm
whats wrong with the injection gear! if you are getting rid of it I may be keen to take it off your hands.!
mike77, Mar 19, 11:39am
I don't think the injection gear would work too well on a Carburetted head as I think there is some machining in the 4.1 injected head that the carburetted head doesn't have.where the injector points towards from the inlet.
Or is the carb head and induction being put on complete!
But I could be wrong.
unclejake, Mar 19, 11:42am
Also: what is wrong with the thread you started yesterday Bladeaimee!
jezz43, Mar 19, 7:02pm
or you could just fix it and not bother playing musical chairs with the heads
carmad50, Mar 19, 7:38pm
mate crush it and get a new one unless u got a enormos bank balance or v8 it more power better economy 351 cleverland 2 brrel headers 26 mpg
cost you around 2 grand set it all up
fordcrzy, Mar 19, 7:43pm
the heads are interchangeable. the injected heads had a slightly revised combustion chamber and lower compression than the carb heads. you may find that you'll need to back the timing off a couple of degrees or run premium fuel or it may ping a bit. (you'll see what i mean about the heads as soon as you compare them, the carb heads have more meat between the valves on one side)
(i had a late model ('86)carb XF s pac that had the electronic ignition setup and the heads looked the same between Injected and carb)
carmad50, Mar 22, 8:55pm
fordcrzy do u know how to set up these dam ford security coded stereos !
fordcrzy, Aug 17, 11:58pm
i posted in your other thread.
