Max compression ratio for a v8
hollyx_, Feb 2, 6:52pm
Building up a holden 308 with early cast heads with a camshaft of around [email protected],want to run around 10.5-11.0 using 98.What CR are you running!
mram, Feb 2, 8:14pm
Have you cc'd your heads! Flat top pistons! typical CR with early red heads and flattops was 9.5-10:1 depending wether pistons were zero-decked and standard cc'd chambers
skin1235, Feb 2, 8:32pm
what are you doing to the breathing, 10.5 - 11 is gonna be hard to achieve without some substantial work ports and valves, and damn hard to maintain
it's getting pretty close to CI, and thats not a good effect on a 308
extrayda, Feb 2, 8:36pm
geez thats a big cam for a motor that small.What is it going to be used for! I had a 244/252 @ 50 in a 383 Chev and it was quite lumpy. I ran 10.0:1 CR, which in theory was a bit on the low side, but the cam worked very nicely, probably helped by a few extra cubes.
elect70, Feb 3, 11:44am
Gonna need some serious milling &deep eyebrows in piston crownswith thatbig stickor,bang,race engine !
hollyx_, Feb 3, 5:57pm
57 cc,zero deck height,heads been ported to make 450 hp @.550 lift,torque power manifold,650 dp holley may go a bit larger,full msd etc.Just a weekend car.
quickbuck, Feb 4, 12:49am
Might be all it lasts!
extrayda, Dec 5, 11:47pm
The only issue I had as far as fitment went was clearancing the rods to not hit the cam lobes (due to high lift).Mine was a crane cam.Chev motor, so clearancing might be quite different in a 308.I assume either manual or high stall, with suitable gearing!I ran with 3.0:1 for the first few 1000 k's, then went to 3.83 (somewhere around that), which woke it up quite a bit :-)
