Honda Odyssey new cant get a 2nd hand one looking but nothing yet. Drivers door side
jezz43,
Feb 10, 9:55pm
ring strong for honda, they seem to have everything. if not, palmerston north partsworld does honda and nissan i think. they are very helpful in sourcing parts
zak1998,
Feb 10, 9:59pm
thanks nothng in the BOP rang around
cassandra13,
Feb 10, 10:00pm
check a local sparky there are several after market no OE ones around. even try places such as Jaycar. much cheaper
zak1998,
Feb 10, 10:03pm
do they work just as good then
jono2912,
Feb 10, 11:32pm
That's better that the $443 for my camry :)
bigfatmat1,
Feb 11, 5:53am
probably because the central lock motor is part of the door lock assy thats cheap in my opinion
pup2,
Feb 11, 6:17am
Sounds pretty good to me
Feb 11, 6:24am
zak--the easiest and cheapest option is to call an alarm installer. They always have motors on board and even with an install you are well under 100
nave12,
Feb 11, 6:37am
Theres a 95 oddessy over at pick a part in Tauranga,you could go have a look at that to see if your actuators are the same and they will be cheap as.
zak1998,
Feb 11, 7:09am
need it for a 1999 - 2004 model
bae13,
Feb 12, 6:10pm
bigfatmat1 is spot on here, there is a reason you cant find second hand units (good ones anyway) and thats because of this being a general fault with hondas
cassandra13,
Feb 12, 7:46pm
fine as.factorys outsource anyway
zak1998,
Feb 12, 8:14pm
tell me I have had 3 others fitted on other doors
elect70,
Feb 13, 1:54pm
Are they a sealed unit . On other cars i've had been able totake them apart & clean them as usually its the actuatorseizing updue todrt& greasegetting in .
