Still waiting for you to come back and fill us all in on the locked up motor after bolting up the transmission.
What happened there!
s.patete,
Feb 19, 7:18am
assuming its a car of some sort I would say ignition module as I have just had the same problem with one of our cars, installed a second hand distributer as it was cheaper and problem solved. PS. Most of the people on here are willing to help and offer advice but Im pretty sure not one of them has a crystal ball that works so a little more info will go a long way.
s.patete,
Feb 19, 7:19am
Snap, there we go.
thunderbolt,
Feb 19, 7:23am
Another point which would be useful.
Has it ever run since the motor swap!
Was it running ok and now wont start which suggests a component failure, or has never run which may relate to the install!
johdoe,
Feb 19, 10:57am
trans oil pump locked up the torque converter an bent the valves in motor so it was a new trans to now all in car just no spark. motor turns over just wont fire up most of the parts are of old motor
johdoe,
Feb 19, 10:58am
s.patete what makes you any different
