Melting plastic headlight plugs/connection.
hamtostie, May 12, 5:54am
Hello team. 1997 Nissan Sentra.
The plugs that clip in to the headlight bulbs have melted, resulting in loose connections that need to be pushed back on regularly. I am looking to replace the plugs, but before I do, any thoughts on why they would be melting! Havent checked the bulbs, but perhaps different wattage!
Thanks in advance, Steve.
paul271, May 12, 6:19am
Very common problem on Nisaans, we do quite a few. Cut another plug off a car at the wreckers,and solder it onto the loom. Make sure you clean up the contacts inside and then click it on.
falcon15, May 12, 6:20am
Its pritty comon on older nissans for this to happen when the plugs are loose and there is a bad conecting it heats up and melts the plastic around the terminals. You can buy new plugs from repco or bnt
dave653, May 12, 12:01pm
If they are loose, couldn't you crimp them a bit tighter! Our VN did the same, but I had fitted 80/100 watt bulbs. Swapped to 55/60 +90's and the problem went away.
hamtostie, May 12, 9:10pm
Thanks for the replies guys. Will replace both and check bulbs.
dent, May 15, 8:34pm
yeah high wattage bulbs and crap connections. You can but heavy duty plugs and solder them in to your loom.
clark20, Feb 23, 12:49am
Any Auto Electrician will have new replacements at a low cost, don't bother with second hand.
