Ford gurus
gmphil, Mar 30, 12:01pm
94 ,xr6 no spark at plugs . Hav used test light and theres power to the plug in dissy ,went to check coil in holy hell where the lol (first ford ever done) found that like the dissy in prick place get to so before ilose skin i ask the gurus coil or dissy first
tatts2, Mar 30, 12:30pm
If you take the air box out its not so bad.
More than likely its the dissy
tonyrockyhorror, Mar 30, 1:03pm
TFI module.
ceebee2, Mar 30, 2:10pm
+1Common
unbeatabull, Mar 31, 8:36am
Common, great fun to replace! Prepare to leave some skin and blood behind
bigfatmat1, Mar 31, 9:11am
the coil is better accessable from underneath it is under the intake manifold further back from the distributor. Coils, pip sensors and tfi modules are all common faults.
brokebloke1, Mar 31, 11:54am
OH yes pr**K of a place for coil pack we have a AU2 XR6 replaced sparkleads at same time
unbeatabull, Mar 31, 3:03pm
Yup, you may as well do the whole lot while your under there, cause once you do it once, you won't want to do it again!
cleverrock, Mar 31, 4:56pm
horrible things to work on. doing coil , dizzy etc on my EB xr6 at the moment not an easy job
gmphil, Apr 5, 9:48am
Hopfully bits be here today , is the firing order 153624 or 42 cheers
