Can anyone help with Ford Fairmont problems?
kslatt, Feb 3, 6:11pm
The car was going fine, being used daily. One day parked it up for the night, next day just would not start. Dash lights come on, radio goes, everything seems fine until I turn the key to start it, the brake fail light comes on the dash and she wont even turn over. Was previously told it was the battery, but have charged it and even tried to jump start it, same thing happens. Any ideas!
unbeatabull, Feb 3, 6:12pm
What year . if its BA onwards it probably has a Calcium Battery in it which some cheap chargers won't charge.
When you turn the key does it make a clicking sound!
kslatt, Feb 3, 6:16pm
its a 1993.yep it clicks and the brake fail light flashes on, when I let the key off the light goes off
jason18, Feb 3, 6:20pm
Take to sparky. Run multi metre over it if buggered get new battery
kslatt, Feb 3, 6:21pm
we tried a new battery in it, didnt make any difference, still doing the same thing
pup2, Feb 3, 6:29pm
poss the starter is having "issues". Check to make sure all connections are good, tight and clean before heading into your local auto sparky
taipan4, Feb 3, 6:30pm
check connections to solenoid & starter motor also check for build up of corrosion on inside of battery terminals as this can mean high resistance
joints. If possible using a multimeter, check voltage at starter motor when someone else turns the key, & if you get less than about 11.5 v then theres a high resistance joint somewhere
kslatt, Feb 3, 6:33pm
thats great thanks! but I have another questions lol.i cant even find the starter motor.can you give me idea where it will be!
jmma, Feb 3, 6:38pm
Oh dear, take it to a sparky!
kslatt, Feb 3, 6:43pm
haha I know I am terrible.I have a fair idea where it is but was hoping someone would tell me as well just so I can make sure
plus its kinda hard to take it to a sparky when it doenst go lol
steve312, Feb 3, 6:46pm
Starter is on the rear of the engine on the passengers side of the car.Have a look under the inlet manifold and there it is:o)
jmma, Feb 3, 6:49pm
Is it manual of auto, how long have you had the car!
kslatt, Feb 3, 6:52pm
its auto and we have had it for a very long long time lol maybe more than 15 years
thanks steve312, thats a great help
jmma, Feb 3, 6:57pm
Maybe inhibitor switch (don't ask me where that is(o: ) playing up, have you tried starting in neutral or wiggling the gear shift around!
skull, Feb 3, 6:59pm
Sometimes giving the starter nmotor a solid whack on the outside (not to cause damage) will get it working again. If it does go straight to Auto Electrician and get it fixed.
bentcoupe, Feb 3, 8:20pm
mine wont start when hot
jenny188, Feb 3, 9:14pm
Had friend who had mid 80's Fairmount. he backed it down boat ramp and switched it off. It never went again. Towed it and boat up to the top of ramp and it was transported away and we took the boat home. Computer fault never to run again. New ecu unit.
robotix1970, Feb 3, 11:19pm
when you take it to the auto sparky, ask them to also check the igition module / hall effect plate in the dizzy . Ohh year as for the inhibitor switch goes., it's located on the side of the auto transmission with about 5 wires coming off it where the selector linkage is. (under the car) but good luck with it all the same. (i love the nice photo of the wee kitten)
barbuzz, Feb 4, 10:27am
Put it in "park" & rock car back & forth a bit. Then try to start it.
jash3, Feb 4, 12:17pm
Starter could be jammed!
elect70, Feb 4, 1:26pm
x1
Check rear bush in starter motor . If worn, armaturecontacts the pole pieces & it will draw600amps + Hapened on my coon
fordzfly, Feb 4, 3:21pm
is it a e series with smartlock! if ef/el try hitting the dash justto the left of the dash cluster/above stereo.
bob1088, Feb 4, 4:09pm
It`s probably a bad earth problem - had the same on Fords - check and clean all earth contacts - maybe wrong but an auto elec can sort it.cheers.
