Rear de-mister not working
ntm4, Apr 4, 9:39pm
Hi there.
Have a 96 corona premio, the rear de-mister has not worked since I bought it. I thought it was the switch as it doesnt "clip" in when pressed and the light doesnt turn on even when kept in.
But I went to pick a part and took the switch out of an identical car and it doesnt clip in either.
Any ideas! Is this a common problem with the switch! All fuses are fine.
Thanks
r15, Apr 4, 10:08pm
not a huge amount of help, but a lot of toyotas use a button like this and you press it for a moment and then the demister will run for a few minutes then turn off. so probably not the switch.
tonyrockyhorror, Apr 5, 12:12am
Checked for continuity between the terminals on the demister itself!
gadgit3, Apr 5, 5:31am
No light then not working. check the fuse
skin1235, Apr 5, 6:00am
also
no light = no continuity in circuit, check with ohms meter between the ends of the window foils, ( disconnect one end)
