reason being i couldnt see out the back window it was blurry i ripped off the tint off the rear window and it has a sticky residue left on it how do i clean it off thanks
turton,
May 27, 1:09pm
should use a heat gun to remove tints properly. Probably need a heat gun and a plastic scraper to get the residue off
n1smo_gtir,
May 27, 1:13pm
i found citrus cleaner does a good job at this.
saxman99,
May 27, 1:25pm
Meths!
mercbens,
May 27, 1:29pm
De-Solvit removes the sticky residue. Mitre 10 has it
chris241,
May 27, 1:47pm
i used thinners straight onto the tint once and it took it off easy
inkapuka,
May 27, 2:03pm
someone suggested engine degreaser that migt work!
neo_psy,
May 27, 2:50pm
Hot soapy water and green pot scourer worked for me.
faa_luke,
May 27, 3:24pm
Just go easy as you'll take the demister off if you're not careful. So no scrapers etc.
slarty45,
May 27, 4:19pm
WD40
matthew111,
May 27, 5:43pm
soap and water
flybye_in_a_rx7,
May 27, 6:12pm
soapy water and elbow grease worked for me. not too sure if elbow grease is ok to use on rear window because of the demister
noelsgimps,
Jun 3, 9:01am
We take this sort of stuff off all the time. Have found turps to be the best. Spray on and let soak for a minute or 2 then scrape off. Be very careful around the demister.
