can i use a 3 speed xf colum change colum to convert a xg to colum change . xf 3 spd auto xg 4 spd auto!
quickstitch,
May 23, 7:00pm
i can't see why not, you will need to modify the gate on the column change by adding a little more travel, add another notch under what was first gear. we have modified a column change to use a B & M cable, so anything is possible with a little kiwi ingenuioty (i know that is spelt wrong but i can't see the dictonary)
roys351,
May 23, 7:13pm
thanks that sounds good any idea if xf linkages will fit as im not having much luck finding xg stuff !
