Trans Fluid change '94 SV41 Camry
leofam, Jun 11, 7:45am
Can someone please explain the necessaries of the above!
I'm competent to remove the pan, clean/replace filter, fluid & gasket HOWEVER - some forums say this model doesn't have a filter and a heap of contradictory info is just confusing and mostly posted in the U.S. (they have some funny ideas)
As we live rurally, need to ensure I have all I need to do the job before I start.
What sort of fluid and how much!
Do I need a filter or is there just a mesh to clean!
Is there only the pan gasket to replace!
Is their a drain bung or do I just remove the pan!
Do I just refill completely with a narrow funnel through the trans dipstick hole or partially refill pan before refitting and top up via dipstick hole!
Thanks in advance : )
luke041, Jun 11, 8:16am
Yes there is a filter. You will dx3 about 3.5l if you are just taking the pan off or around 8l if you flush it to. Yes there is a drain bung and yes you fill it through the dipstick hole
And yes just a pan gasket.
leofam, Jun 11, 2:31pm
