have a 1993 4055 door hatch auto, just done 400 klmsandorange light came on so topped it up and managed to put 57.55 lt into it ,the car tank is 65 lt . Can some on work out the economy for me please ,and tell me if it is good or bad! had a stroke a while a go and numbers are not my best friend ;thanks
andy61,
Jun 6, 11:48am
Shocking ,my Fielder did 700+kms to 41 litres
brokebloke1,
Jun 6, 11:56am
our Falcon XR6 does about 600 kms to 55litres on the open road
smac,
Jun 6, 12:18pm
Assuming you filled it before starting the trip meter, you're getting 14.4l per 100km. If you didn't fill it before starting to count the k's, there is no way of working it out (I suspect you didn't).
14.4 in a 2l car is pretty bad, unless it was 400km around town, towing a house.
sas777,
Jun 6, 12:20pm
Use a formula like this:
litres used / kilometres driven x 100.
I can't work it out for you as unsure of your fuel usage from post.
If you then want old school (British) mpg then 9.42 is exactly 30 to the gallon.
tazcsv,
Jun 6, 2:13pm
If thats 400ks to 57l you have a problem, my twin turbo subaru gets 550ks to 55l.
forget working it out off what you have already done. You need to run this tank down then brim it again. record the k's that you get out of this tank and how many litres it takes to top it up. Once you have those two figures you can divide the litres you put in by the number of kms in units of 100km.
For example 567km and 55 litres: 55 ÷ 5.67 = 9.7L/100km
mantagsi,
Jun 6, 5:35pm
1997 Toyota Caldina 2.04wd turbo (manual, stock standard) - nets me 500kms for 45 - 50 litres, lots of motorway driving. Dash display tells me Im averaging 11km per litre, can get as good as 15km/litre (off the scale) and at worst 6km per litre (terrible, jammed in mway traffic). l conclude that your car is very thirsty!
