the car isn't starting properly once the car is hot at the moment, When it is cold it starts fine and drives ok its just once it is hot it just cranks over won't start until the car has cooled down then it will start up fine again, the engine light on dash is on
2001 Holden astra
where doi start to look, whatis likely to be the problem ! thanks
r15,
Jul 14, 3:57pm
take it to a mechanic with the correct diagnostic tools for your car.possibly a holden dealer would be a good place to start so you dont end up with some other monkey "guessing" what could be wrong whilst telling you he knows what he's doing
kevlight,
Jul 14, 4:52pm
yes looking for a later model hatch for budget $$ ,is a hard role ! but this is the best offer yet if it ca be repairedfor a reasonable cost,whats a temperature senor and crank sensor cost for these cars !.And what are they re badged from.
carmedic,
Jul 14, 5:04pm
Crank sensors about $300 (buy from UK) its a Vauxhall Astra there or Opel Astra in the rest of Europe. McGyver method. Buy a can of freeze spray, run engine until it faults, spray the crank sensor, if it restarts you have found the fault if not look further.
thewomble1,
Jul 14, 8:37pm
petrol vapour lock
