a while ago, someone left a message on a thread, that they were using waste sump oil to power their diesel ute / car! i suppose if you filter the oil & pre heat itdon't see why not ( perhaps avoid this technique in common rail eng )any body tried it !
morrisman1,
Jul 13, 5:44am
A centrifuge is your friend, best way of filtering the oil.
mrfxit,
Jul 13, 7:30am
Google
Bio Diesel Waste oil + cooking oil + centrifuge
the-lada-dude,
Jul 13, 7:38am
yes i know about waste vegie oil,but this fella was using waste engine oil!
he was using a centrifuge filter as said above, i rem it because at the time i googled up how to make one
mrfxit,
Jul 13, 8:29am
WVO is far harder to get clean enough then WMO WVO has a lot more finer partials & water content to clean out then WMO WMO can be heated & centrifuged clean enough to use safetly in older gen diesels WVO needs centrifuge + additives to clean out the water content
next-to-normal,
Jul 13, 1:19pm
you add a little kero to it, might be 5% or 10%
36lafayette,
Jul 13, 1:41pm
been running on wvo for 3 years now just filtering and tip it in tank no problems at all use 4000 ltres so far
the-lada-dude,
Jul 14, 4:17am
who's the best bet for oil ! do they sell it/ give it!
mrcat1,
Jul 14, 12:33pm
Thats why people who have no idea of what they are doing shouldn't be playing with diesels, once it took off they should of strangled it.Running behind the caravan now has cost him a fortune.
