Faulty Chinese Made Tranmission In Mustangs
croco1, Aug 29, 6:57pm
The National Highway Traffic Safety Administration (NHTSA) has opened an investigation into reported transmission problems in 2011 and 2012 Ford Mustangs.
The preliminary evaluation stems from 32 complaints filed with the agency regarding an occasional problem shifting into gear in six and eight-cylinder cars equipped with a 6-speed manual transmission that is manufactured in China. Approximately 26,000 of the cars have been sold.
2011 Ford Mustang GT
Related Video
Muscleconomy
2011 Ford Mustang
Many of the reports focus on a difficulty engaging 1st, 2nd and 3rd gears during both up- and downshifts, especially when the transmission is cold. Others mention a persistent grinding sound and issues with other gears. In addition to the official complaints filed with NHTSA, the topic has appeared on a number of independent websites that cater to Mustang owners. No accidents or injuries have been reported, but several of the complaints mention close calls that were caused as a result of the problem.
Ford has previously addressed an operating issue with the transmissions, which are produced at a facility run as a joint venture between Ford and German transmission specialist Getrag. In March, the automaker issued a technical service bulletin (TSB) instructing service technicians to replace the type of transmission fluid installed at the factory with a different specification that is less susceptible to increased viscosity, the resistance of a fluid to flow, at low temperatures.
Nevertheless, at least one owner alleges that he or she has continued to experience the problem even after the change has been made. The complaint from July 27th, 2011 reads, in part:
"FLUID SWAP DONE, GRINDING WORSE IN 2ND-4TH GEARS. 2ND GEAR LOCKOUT IN LEFT TURN AT 45 DEGREES. 4TH GEAR RATTLE UPON WOT [wide open throttle.] VEHICLE NO LONGER FUN TO DRIVE, WAITING TO GET RID OF IT AS LEMON."
A separate TSB issued by Ford in November, 2010 cautioned that loose clutch bolts could cause difficulty shifting into first gear or reverse.
A FoxNews.com analysis of the recent NHTSA complaints indicates that a number of the owners may not be aware of a special feature found on V8-powered Mustangs that forces the transmission to shift directly from 1st to 4th gear under light throttle application. This is intended to increase fuel efficiency during the EPA fuel economy testing procedure and cannot be turned off, but is overridden during hard acceleration. The manual transmissions in the Chevrolet Corvette and Camaro SS, both built by a different supplier, function in a similar way.
A Ford spokesman tells FoxNews.com the company is "working with the government as they review the matter, and will fully cooperate."
Read more: http://www.foxnews.com/leisure/2011/08/08/nhtsa-investigating-complaints-about-chinese-made-ford-mustang-transmissions/#ixzz1WJQ0cVWB http://www.foxnews.com/leisure/2011/08/08/nhtsa-investigating-complaints-about-chinese-made-ford-mustang-transmissions/
mrcat1, Aug 29, 7:44pm
If you notice now that kiwirail trains that have a new chinese loco on the front also have one of the old locos behind it, they are having heaps of problems with the new locos, sensors shutting down the locos due to our tracks being to rough, the train thinks it is going to derail so it shuts down. And just general issues so they have to have a old loco there so when the new one breaks down the old one can carry on with the trip. so don't think the chinese just put all the problems into their transmissions.
gunhand, Aug 29, 7:53pm
So our crap track system is the chinese's fault. maybe they thought we had real roads and tracks not goat tracks lol.
rlr29, Aug 29, 8:07pm
I've seen a lot of over engineered Chinese electronics with poor (or none) redundancy systems and just plain sloppy assembly.It's like they just totally balls up the basic shit and go straight to the advanced stage.
doug207, Aug 29, 10:33pm
If Ford payed the company they contracted more to develop the gear box and make it, thethere wouldn't be a problem.
grangies, Aug 30, 7:44am
akaniva, Aug 30, 8:38am
That's right, The Chinese make to whatever spec you want. They make some real high-end stuff too, like hi-fi gear.
As for our railways, it must be the most retarded system in the developed world, just crap from A to Z.
richardmayes, Aug 30, 8:54am
Why is this news! It sounds like the Chinese have merely succeeded in making a modern 6-speed gearbox that is nearly (but not quite) as crude as a good old-fashioned 4 on the floor .
Get a Mazda if you want silky-smooth gearchanges!
jason18, Aug 30, 9:20am
Lots of the buses around hamilton are chinese with more hitting the roads! They going strong
elect70, Aug 30, 10:50am
How do they make a manual g box shift 1 -4on its own !Unless its a SMG.Getrag boxes were bulletproofthey used them inATC falcons in the 80sthis is probablyresult ofpoor quality materialor bad engineering .
bubbles244, Oct 8, 11:40pm
they should have just left the mustangs in the safe hands of shelby and Co
