Hi, I have a problem when you button off going down a hill or button off due to a car in front has slow down my car deceidsto slow right down with no brakes like a exhaust brakeon truck and trailer units. What I would like to know if anyone knows is there a fault with the trans or is this common built in thingfor thiscar. Off the plate on the fire wall the motor is a SR20 (DE )1998 CCand trans RL4F03A Its has done 163719 kms. Thank you for any help.
jason18,
Aug 29, 2:27pm
So it slows down very quickly! Sounds like you might have stuck hand brake or something to do with sticky brake calipers !
morrisman1,
Aug 29, 3:13pm
does the engine rev higher or anything during this phase! The manual ones switch the injectors off on the over-run but I dunno about autos.
How quickly is quickly!
john26a,
Aug 29, 3:16pm
No not the brakes just hadWOF check.
john26a,
Aug 29, 3:17pm
Engines revsdrop off dose not rev higher. Very quickly.
morrisman1,
Aug 29, 3:29pm
is it any different if you knock it into neutral when coasting!
john26a,
Aug 29, 3:32pm
Have not tried it knocking into neutral.
john26a,
Aug 29, 3:35pm
Apart from needing a tune up gosfine with no noises in the gear boxor motor. But will you back off on the acc pedal then this happends.
