Suzuki Swift, no power when cold?
dasfi, Aug 23, 4:15pm
Suzuki swift has no power and will barley accelerate when engine is cold!
Its an auto and cvt Trans
bwg11, Aug 23, 4:55pm
I assume it is a 2012 Sport if it has CVT. My wifes has tons of grunt when cold although we do nurse it until it warms up. Yours must have an issue.
moosie_21, Aug 23, 4:57pm
Replace said 1.5L engine with 2JZ-GTE. Problem solved.
dasfi, Aug 23, 5:59pm
No its not a 2012, pretty sure its a 2008
morrisman1, Aug 23, 6:04pm
Does it feel like the engine is the issue or the transmission!
ema1, Aug 23, 6:07pm
Take it a Suzuki dealership workshop and have the diagnostics codes checked for error codes, this should show what's at fault hopefully.! Certainly sounds like something is amiss with the car for sure.
dasfi, Aug 23, 6:14pm
engine maybe it wont rev under load in gear, not slipping or missing
ceebee2, Aug 23, 6:58pm
Does the "check engine lamp" go off after start up! Any warning lamps on.
kazbanz, Aug 23, 11:57pm
OP--Im guessing once warmed up the problem goes away!
is the car just barely idling when cold!-or even idling at sort of normal speed!
dasfi, Aug 24, 8:53pm
check engine light goes away, yes once warm it goes fine and it also idles fine
