Suzuki Swift - Ball Joint
intrade, Aug 2, 7:28pm
id fit new disks instead. and balljoint all depends if its a whole suspension arm or bolted joint etc. post plate of car for better idea. you can also go look at partmaster supercheap what it cost and then about 2.5h labour as sortof max what ever they charge 250 for labour+-
intrade, Aug 2, 7:36pm
kazbanz, Aug 2, 11:35pm
About $600 all up -and I agree with Intrade the labour involved in replacing disks is the same as for skimming.( counting the actual skimming as "outwork' not labour) Skimming they charge out at about $80 a set -disks are about the same. good news is that you have to 'do' the job anyway to get into the ball joint
bigfatmat1, Dec 14, 3:55am
Skim disks $100 ball joint $75 1.5 hrs labour. + gst
