2004 Corolla, Headlights.
wildwest3, Sep 3, 5:09pm
Evening all. I haveheadlights not working, except in 'Flasher' mode, I've found the under bonnet fuses, and checked them. Does anyone know where the relays are!
Any similar problems !
Cheers all!
grangies, Sep 3, 5:11pm
So the lights come on when the indicators are going!
a.woodrow, Sep 3, 5:11pm
Do you mean the high beams work but not the low beams! Check the bulbs
littlebob7, Sep 3, 5:14pm
Above the "glove box " on the passengers side of interiorof car is a whole lot more fusesIf you have a phillips screw driverits easy to remove the drop downglove box& lots of fusesare easy to get at
wildwest3, Sep 3, 5:22pm
Yes, I found that LIttleBob! with out dropping the glove box, I got the cover off, and read it. There was no mention of anything like Lighting.
cowlover, Sep 3, 6:02pm
Are the rest of the lights working!If not I'd be inclined to thnk the switch is dead.
wildwest3, Sep 3, 6:15pm
On the light switch, side lights OK, Headlights low and high, no go. Headlight flasher OK
ceebee2, Sep 4, 2:29pm
When you flick from high to low you should hear a relay click. If not then the switch is probably faulty. If you can hear the relay click then the relay or main head lamp fuse is faulty / blown.
