BA FALCON WAGON LSD
kenw1, Sep 11, 6:44pm
Is it possible to put a LSD into a BA Falcon wagon as a straight swop for the existing diff!if it is where do I look for the LSD, and any idea of dollars! thanks
gofer0007, Sep 11, 8:19pm
Yes, my buddy just did the research on doing it for his wagon to tow his off road truck n trailer on forest roads.Wreckers in Hamilton quoted $250 for the LSD and then it needs to be fitted which is easy.
Aussie spares in Hamilton I think it was.
unbeatabull, Sep 12, 6:36am
Good chance the ratio could be different. Can get different speed sensors for the trans to suit the diff otherwise just keep in mind it will be out a bit.
Being a wagon, it is a pretty easy job as well. If it was a IRS rear end it'd be a bit more work.
fair_lane, Sep 12, 6:46pm
Has anybody put one into an AU V8 wagon with traction control!
fair_lane, Sep 12, 6:55pm
Hmm, did it work OK with the traction control!
tandj3, Sep 12, 6:58pm
I just changed from a 3.45 ratio diff with LSD because the LSD in ford ba xr6 are crap ford have always had problems with them just google it they start to whineand the LSD craps out approx 2 to 3 thousand to fixI changed mine to a 3.23 ration from a standardba falconal up cost about 600.00 dollars I will be using ba diff LSD parts as fishing sinkers all they're are good for
timmo1, Sep 13, 11:34am
It's near the back
unbeatabull, Sep 13, 3:49pm
The problem is people putting the wrong fluid in them, or not changing them at the right interval.
Traction assist worked fine, as it is not part of the diff itself. As long as all the rest of the parts, sensors etc are ready to bolt on there won't be a problem.
fair_lane, Sep 13, 4:56pm
Agree, you do need to change that oil at regular intervals and use a decent quality synthetic of the right viscosity.
I was just curious as to whether the LSD would fool the traction control but I assume they use the ABS sensors to detect wheelspin. Does that sound right!
I've spoken to others with the V8 wagons and most would prefer an effective LSD over the traction control as they can leave you a bit stranded 1/2 way across an intersection if it clicks in at the wrong moment.
unbeatabull, Sep 13, 5:02pm
Yup, the traction control is all done through the ABS System.
You can turn it off btw . Or at least ya can in BA onwards. Can't remember if AU have the button on the dash to turn it off or not.
kenw1, Sep 13, 5:05pm
Thanks for all the replies, especially "It's near the back" that brought a smile to my day.
I am just getting fed up with getting one wheel on a bit of mud or slippy and that is it.
Does the LSD bit work when you are reversing! anyone know.
unbeatabull, Sep 13, 5:05pm
Yes it does
