Sell it and buy a Ford. Not the cheapest option I might add.
NZTools,
Sep 19, 7:01pm
Sorry, but i'm a bit busy. lol
evotime,
Sep 19, 7:02pm
They're complete hubs held on by 3 Allen keys.
bigfatmat1,
Sep 19, 7:03pm
dont you buy the whole hub assy so you dont replace just bearing
axeman.,
Sep 19, 7:08pm
can i replace just the bearings
evotime,
Sep 19, 7:12pm
Theyre sealed units so no. Short answer
kevymtnz,
Sep 19, 7:15pm
quote dont do it
evotime,
Sep 19, 7:24pm
It won't cost a lot labour wise to pay a mechanic 1/2 hr to 45mins to fit it Unless you have a trade quality Allen key/socket set you won't get the bolts out. If you wreck the heads of the bolts having a go you'll double or tripple the cost of the job
axeman.,
Sep 19, 7:36pm
how much is a wheel bearing
whqqsh,
Sep 19, 7:44pm
good grief! Allen keys! I usually use those for undoing cap screws, what clever people Holden are, using tools as fastenings
treachug,
Sep 19, 8:09pm
Genuine! around $580 if I remember. You can purchase aftermarket ones that may last 6 months (have heard reports from a customer) or may last years - depends on quality. Just how much you want to spend on that quality is the telling thing.
treachug,
Sep 19, 8:10pm
hahaha.saves time on removal!
evotime,
Sep 20, 5:55am
Well done, ok held by 10mm bolts from memory with a female hex
twink19,
Sep 20, 6:21am
people fixing things like wheel bearings that dont know how, warrants being done away with, the roads are going to become one scarryplace
smac,
Sep 20, 6:36am
One of those things isn't happening, and the other has ALWAYS happened.
whqqsh,
Sep 20, 2:17pm
yeah, cap screws
axeman.,
Sep 20, 6:21pm
Does anyone know if the allen key bolts need to be done up to a certain torque!
shakespeare6,
Sep 20, 6:27pm
yepand you will need more then an allen key setwill require a socket.also 10mm bolt to remove abs connector from hub left and right hubs are different. Pirate hubs are arount $180 through BNT but real mixed bag if you get a good one or not. Pay to by genuinewhich are about $450 from holden
axeman.,
Sep 20, 6:39pm
thanks do you know the torque Nm
kingfisher21,
Sep 20, 6:59pm
100-115Nm
